Street light automatic controller circuit diagram using power switch
Source: InternetPublisher:containsmachine Keywords: Automatic controller controller circuit diagram power switch resistor Updated: 2020/09/02
Circuit working principle: The light-controlled street light circuit consists of a power supply circuit and a light-controlled circuit, as shown in the figure. The power circuit is composed of power transformer T, rectifier diodes VDl-VD4 and filter capacitor C. The light control circuit consists of photoresistor RG , resistors R1, R2, variable resistor RP, electronic switch integrated circuit IC, relay K and diode VD5. After the AC 220V voltage is stepped down by T, rectified by VD1-VD4 and filtered by C, it provides +12V working power for the light control circuit. During the day, RG is exposed to light and becomes in a low-resistance state, causing the IC's pin 2 (strobe terminal) and pin 4 (output terminal) to be at high level. Its internal electronic switch is in a cut-off state, K does not pull in, and the street light EL not bright. At night, when there is no light, the RC is in a high-resistance state. Pin 2 of the IC becomes low level, the internal electronic switch is turned on, and the EL lights up. Adjusting the resistance of RP can change the sensitivity of the light control.
![1A44224B-0.jpg](http://www.eeworld.com.cn/circuit/upload/63e0921b7cb078f96f992069c1bb76e1/66305c974cba389e5dc5aae5e91fad70.jpg)
Rl and R2 use 1/4W metal film resistors or carbon film resistors. RP uses solid variable resistors. RG uses RG45 series photoresistors . C selects an aluminum electrolytic capacitor with a withstand voltage of 16V. VDl-VD5 use 1N400l or lN4007 silicon rectifier diodes. The IC uses the TWH8751 electronic switch integrated circuit. K selects JZX-22F type (contact current load is IOA) l2V DC relay, and its two sets of normally open contacts can be used in parallel. T selects a power transformer of 3-5W and a secondary voltage of l2V. You can make your own printed circuit board during production, or you can use a universal printed circuit board. After the circuit is installed, as long as the wiring is correct, it can generally be used normally without debugging.
- The basic principles of power supply design. What are the key components of a power supply?
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Schematic diagram of car cigarette lighter to USB power port
- 220V Remote Load Monitor
- Driving circuit of switching power supply field effect tube
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Dual forward converter schematic diagram
- Adjustable regulated power supply with current limiting protection
- Electric bicycle battery charger circuit
- Detailed explanation of mobile phone charger circuit diagram
- Typical Reference Voltage and Power Supply Circuits
- Power supply circuit with multiple outputs (MAX1902)
- One of the liquid level automatic control circuits using power switch integrated circuit (fill-in type)
- Delay lamp circuit using power switch integrated circuit (2)
- Using ER1211 ASIC as automatic exposure controller circuit diagram
- Circuit diagram of small power switching power supply with output of 5v/0.4a
- Monolithic electric pump controller circuit diagram
- Telephone extension controller circuit diagram
- Clever use of LM386 as a two-color music lantern controller circuit diagram
- Telephone automatic message controller circuit diagram
