Delay lamp circuit using power switch integrated circuit (2)
Source: InternetPublisher:宋元浩 Keywords: power switch integrated circuit Updated: 2021/07/24
It is a delay lamp using a power switch integrated circuit with another connection method. This LU circuit uses
the strobe terminal of TWHS751, that is,
pin ②, to control the
level state of pin ④ of the output terminal . It is just that the high and low levels of its level
control the output terminal and the high and
low
of the input terminal (i.e., pin ①). The control levels are reversed. When the switch SB is pressed
, the electric lamp E
lights up through In, and at the same time. 220V AC city
electric decoder JE, VD1 ~ VD4
rectifier, input current voltage of about L2V. Because of the capacitance C, the voltage at both ends is small and can cause sudden changes. The ② pin of the power switch integrated circuit
is low level, and the LL pin ① is island level, so the output terminal ④ pin is low level . The relay K acts to pull in, and
the electric shock k1 is closed, so that Button SB is white-locked, so after releasing SH, lamp E can still light up the cup. Then
the DC power passes through R. Turn on the power to f1, so that the voltage at terminal c continues to rise. When it rises to 16V,
the final Darlington tube inside TWH87j1 is cut off, the ④ pin is suspended, the relay K is released, the contact kl jumps open, and the light E Off
. The iLL path delay time is mainly caused by Qiu and C. The charging time is determined by Chang Jing.
- How to use a microcontroller to control a servo motor?
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- A small improvement on the ordinary refrigerator motor starting circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Using P110C to control 6 DC motors simultaneously
- Add one more component to improve the phase failure protection function
- Design and manufacture of three-phase motor protection circuit
- Design and production of no-load automatic power-off device for household power supply
- An experimental model of an infrared radio alarm
- Infrared blocking alarm device
- Agricultural spraying and insecticide control circuit
- Egg heating control circuit
- Flashing wall light control circuit
- Micro remote control receiving and control circuit
- PLC transmission line automatic reclosing control circuit
- Automatic tuning control circuit
- Neon light control circuit
- Load limiter circuit using power switch integrated circuit
- Thermostatic control circuit using power switch integrated circuit
- Touch delay lamp circuit using power switch integrated circuit
