Wideband transconductance operational amplifier and buffer circuit composed of OPA660
Source: InternetPublisher:刘德华河北分华 Keywords: buffer Updated: 2024/09/06
The OPA660 is a general-purpose integrated circuit designed for broadband systems, including high-performance video, RF, and IF circuits. The OPA660 contains a broadband bipolar voltage-controlled current source and a voltage buffer amplifier. The voltage-controlled current source or transconductance operational amplifier (OTA) can be considered an "ideal triode". Like a triode, the OPA660 has three poles: a high-impedance input (base), a low-impedance input/output (emitter), and a current output (collector). The OTA is self-biased and bipolar, and the output current is zero when the differential input voltage is zero. The alternating current (AC) input is centered at zero, producing an output bipolar current centered at zero. The transconductance of the OTA can be adjusted with external resistors, allowing a trade-off between bandwidth, quiescent current, and gain to determine the optimal design. The open-loop buffer amplifier provides 850MHz bandwidth and a 3000V/μs conversion rate. Like the basic component module, OPA660 has simple AGC amplification, driving LED as optical fiber emitting light, fast pulse integrator, fast control loop amplifier, capacitive sensor and control amplifier of effective filter. OPA660 adopts 8-pin plastic DIP and SO-8 surface package, which can be used for basic line recovery circuit, video/broadcasting equipment, communication equipment, high-speed data acquisition, broadband LED driver, AGC multiplier, nanosecond pulse integrator, control loop amplifier, 400MHz differential input amplifier, etc. The pin arrangement of OPA660 and its equivalent circuit are shown in the figure. In the figure, Io=20mA, G=1 R3/2Rs=3.
- The unidirectional conduction current of the diode, the diode and its common uses
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- What does a rectifier do? What is the process of rectification?
- This article will tell you the hard requirements of operational amplifiers
- How does sand become chips?
- Causes and solutions for noise in digital Class D amplifiers
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Current amplifiers and buffers
- The latest application principle circuit of CFB amplifier
- Tone control circuit with buffer
- Active integrator circuit diagram with inverting buffer
- AD7520 double buffer interface through 8031P0 port
- Broadband operational transconductance amplifier buffer OPA660 circuit diagram
- Precision Unity Gain Buffer Circuit
- Buffer circuit diagram for isolating capacitive loads
- 250mA high-speed buffer BUF634 circuit diagram
- Broadband buffer circuit
