Interrupt scan method matrix keyboard circuit
Source: InternetPublisher:qoistoochee128 Keywords: Matrix keyboard keyboard circuit CPU Updated: 2021/10/11
Shown is the hardware schematic diagram of the interrupt scanning method. All column line outputs are low level . When no key is pressed, all row
lines are high level. After passing through the 4-input NAND gate, the output is low level, and then sent to the interrupt application section IRQ2. This No interruption will occur. When any
key is pressed, the row line of the corresponding key becomes low level, causing the output of the 4-input NAND gate to become high level . At this time, IRQ2 generates a positive transition and applies for an interrupt
to the CPU. . After the CPU responds to the interrupt, it calls the keyboard program 1 of the aforementioned timing scan method to find the pressed key and perform
corresponding processing.
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- An article explains the working principle of the Wheatstone bridge
- How does a series arrangement of Zener diodes affect the electrical behavior?
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What is the difference between CPLD and FPGA?
- Working principle and truth table of JK flip-flop
- Beautiful crown wreath made with LED
- Important things to know about PCB routing and how to design the right routing for your PCB
- Share a Motorola amplifier circuit
- Build a musical fountain using Arduino and sound sensor
- Relationship between PCB & Integrated Circuit
- Circuit example of CPU driving multi-bit liquid crystal display tube
- Circuit and working status of CPU output channel b
- External circuit structure of CPU clock signal generation circuit b
- External circuit structure of CPU clock signal generation circuit a
- External circuit structure of CPU clock circuit
- Recorder graphic equalizer drive circuit
- CPU power supply circuit using RT9214 chip
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Simple power-on delay trigger circuit
