Interface circuit between DAC0832 and 8-bit CPU
Source: InternetPublisher:走马观花 Keywords: CPU interface circuit DAC0832 BSP Updated: 2020/10/31
The circuit of DAC0832 connected to 8086CPU in single buffer form is shown in Figure 27-13. Since there are 8-bit data inside the DAC0832,
an interface circuit must be set up between the CPU and the D/A converter to realize data transmission, address selection and read and write control. If there is no input register inside the D/A
chip , an additional circuit is required. Register, starting from the reliability of the system, it is necessary to add a data buffer to the interface. Figure 2 7-14 is the interface circuit
between DAC0832 and CPU . DO~D7 are 8-bit data lines from the CPU. In order to improve
the driving capability of the data bus, DO~D7 must pass through the data line driver Ul (74LS244)t and then be connected to the data input terminals (D10-D17) of DAC0832.
WR is The write control line of the CPU; A10~A15 is the address line of the CPU. After being decoded by the U2 (74LS138) 3-8 decoder, the interface address
signal is generated. Since the address line AO-A9 does not participate in the decoding, in Figure 27-14 The interface address of DAC0832 is 2000H~23FFH. When
D/A conversion is required , the CPU only needs to execute one output instruction to transfer the converted 8-bit data to the data input terminals Dl0-DI7 of DAC0832 through DO~D7 through UI; and immediately start the D/A conversion. , the corresponding analog voltage is output at the op amp output terminal VOUT.
- Analysis of the flow direction of transistor current
- How does a series arrangement of Zener diodes affect the electrical behavior?
- In-depth analysis of energy losses in oscillation frequencies
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- Datasheet/Pinout/Technical Specifications of LMC555
- Basic characteristics/working principles and application circuits of tunnel diodes
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Tutorial on building a NOT gate using BJT transistors
- Simple LED advertising light circuit
- Homemade air conditioner outdoor unit shutdown indicator
- Excellent performance household inverter power supply circuit
- Electric massager circuit
- Inpatient pager circuit
- Electronic anti-asthma circuit
- Straw returning to field crusher circuit
- Farmland irrigation automatic control circuit b
- Diode square rate detection circuit
- Inductive feedback oscillator circuit
- Wireless microphone circuit
- Guest arrival signal recognition circuit
