It is the interface circuit between AD574 and printer.
Source: InternetPublisher:三岁就很酷 Keywords: Printer interface circuit AD computer Updated: 2020/02/01
It is the interface circuit between AD574 and printer . The computer 's printing interface has two write registers, one is a data register with an address
of 3BCH, and the other is a command register with an address of 3BEH. There are also three read registers: the read data register at address 3BCH,
the read status register at address 3BDH, and the read command register at address 3BEH. As can be seen from the figure, AD574 is hung on the printer interface
. First, OFFH is written into the data register (3BCH) of the printer interface through software programming. Make pins 2 to 9 on the DB25 pin
a positive pull-up level} Secondly, start the A/D in reduced range, first write 03H to the command register of the printer interface, so that the cs and R/
C on AD
5 74 and AO are both low level, starting 12-bit/VD, and then writing 04H to this register. Disable cs, R/C and AO; again,
judge whether the AlD conversion is completed by reading the status register (3BDH). When D3 -1, A/D conversion is in progress. When D3-0,
the A/D conversion has ended; finally, the A/D conversion result is read into the computer . .
- How does a series arrangement of Zener diodes affect the electrical behavior?
- Analysis of the basic principle of measuring resistance by bridge method
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What is power factor and three ways to improve it
- Diode-based clipping circuit
- Ceramic filter structure/working principle/characteristics/application
- Build a musical fountain using Arduino and sound sensor
- Tutorial on building a NOT gate using BJT transistors
- Experimental circuit based on 4040 binary adder counter
- Make a simple AM radio with digital circuit
- Basic application circuit of AD590 c
- AD574 and RS-232C interface circuit
- Internal block diagram of ADP3000 integrated circuit
- Three-way DC-DC converter circuit
- D/A conversion circuit based on AD5542
- AD524 simple thermocouple amplifier circuit
- Using AD586 to generate - 5.000V voltage circuit diagram
- Highly regulated power supply circuit diagram using reference regulator AD580
- AD574 is used in 8031 system
- AD590 remote temperature measurement circuit
