AD574 and RS-232C interface circuit
Source: InternetPublisher:刘德华河北分华 Keywords: Interface circuit RS-232 AD A/D conversion Updated: 2020/03/19
In many applications, it is required to send the A/D conversion results of analog signals to the computer through the computer's serial interface (RS-232C)
. For this purpose, an A/D conversion connected to the RS-232C interface has been designed. The interface circuit is shown in Figure 27-9: As can be seen from the circle, this
is an intelligent interface controlled by a microcontroller. Standard RS-232 C communication is implemented between the computer and the microcontroller 89C2051.
The parallel A/D interface connection is realized between the single chip microcomputer 89C2051 and AD574. Under normal circumstances. AD 574 - has been working. The A/
D is started by 89C2051. After the A/D conversion is completed, it will automatically request an interrupt to the microcontroller. After the microcontroller responds to the interrupt, it will take away the AJD conversion result and save it in the
internal RAM. Start it. A rvD conversion. This process continues in a loop, and the computer can
read the A/D conversion results to the 89C2051 at any time according to actual needs. The disadvantage is that due to the influence of the serial communication baud rate, the update speed of the AlD data is limited.
- What is a photocoupler and how to select and use one?
- Analysis of the flow direction of transistor current
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- How does a series arrangement of Zener diodes affect the electrical behavior?
- What is an ac to dc transformer in circuit design
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Analysis of the working principle of CMOS/CCD image sensor
- Datasheet/Pinout/Technical Specifications of LMC555
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- AD7730 digital pressure measurement circuit
- AD7715 internal functional block diagram and pin function diagram
- AD594 to 597 basic application circuit b
- AD574A Unipolar and Bipolar Input Circuita
- M2150AD application circuit
- D/A conversion circuit based on AD5542
- AD524 simple thermocouple amplifier circuit
- AD22103 type temperature sensor circuit
- Precision current source circuit diagram using AD586
