Mono integrated circuit OTL power amplifier circuit
Source: InternetPublisher:ghaytweyhtoo Keywords: Mono integrated circuit power amplifier circuit Updated: 2020/01/29
Among the main power amplifier circuits of combination audio, the most commonly used is the integrated OTL power amplifier circuit. The working principle of this circuit
is the same as that of discrete component circuits. The figure shows the mono integrated circuit OTL power amplifier circuit .
In this circuit - IC I is an integrated power amplifier and it has total 10 pins. U is the input signal, which is coupled through C1 and
fed into the internal circuit of IC I from pin ①. The signal amplified by the voltage amplification stage, the push stage and the power amplification stage is output from the ⑦ pin of ici, and
added to the speaker SP1 via island coupling.
- Homemade high quality preamplifier tone circuit
- Practical and high-performance preamplifier circuit
- Make the most beautiful sound with the least money
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- The fun of making ISD1820 voice recording box
- Amplifier circuit made by parallel connection of FU-50
- Electronic bird repeller for crops
- Typical application circuit of LM4903/4905 audio power amplifier
- LM4902 differential input audio amplifier circuit
- 8W audio power amplifier circuit composed of LM2002/LM2002A
- How does the power amplifier circuit diagram work?
- Relationship between PCB & Integrated Circuit
- Level display circuit diagram composed of LED level meter driver integrated circuit
- LED indicator integrated circuit circuit diagram
- OTL low frequency power amplifier circuit
- Power amplifier circuit with comprehensive compensation
- Integrated OCL power amplifier circuit composed of TDA2040
- Integrated circuit BTL amplifier 02
- LM378 two-channel audio power amplifier circuit with adjustment circuit
- Transformer output power amplifier circuit diagram
