Touch-type electronic dimmer circuit composed of CD4028
Source: InternetPublisher:刘德华河北分华 Keywords: Touch control dimmer circuit Updated: 2024/09/03
The touch dimmer shown in the figure uses a "parametric solid-state relay" (PSSR) as the main control element instead of the commonly used bidirectional thyristor. The dimming process adopts touch mode, which is easy to adjust. The circuit composition is shown in the figure. This circuit consists of a touch control signal input circuit, a step control pulse generator, a pulse signal up/down counter, a pulse signal decoding distributor, a ten-level control switch and a parametric solid-state relay.
- Design and selection of electric control valve system drive
- How to remotely control devices using ESP8266 and LPC2148
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Tutorial for building a remote-controlled Arduino Air-Boat
- Perform surgery on the speaker protection circuit
- Add one more component to improve the phase failure protection function
- Light-controlled circuit design and analysis
- Guanghua brand anti-theft doorbell electronic lock circuit
- Water supply reminder after water outage
- Password type motorcycle anti-theft device
- Agricultural spraying and insecticide control circuit
- Differential amplifier emitter negative feedback gain control circuit
- Switching regulated power supply circuit
- Infrared voice control circuit
- Assembly line outage monitoring circuit
- PLC transmission line automatic reclosing control circuit
- Automatic tuning control circuit
- Timing and fire power control circuit
- Sprinkler control circuit using AC motor
- Forward and reverse control circuit of micro DC motor b
