Darkroom exposure timer circuit using 9300
Source: InternetPublisher:笑流年 Keywords: Timer Updated: 2024/09/02
The darkroom exposure timer circuit is shown in the figure below. It can provide timing control from seconds to minutes. After pressing the start button SB to trigger the music integrated circuit, the music signal is rectified and filtered into a DC voltage, which turns on the switch tube VT, closes the relay K, and the load works. When the song ends, VT is cut off due to the loss of bias voltage, K is released, and the load stops working.
Adjusting RP can change the music rhythm, that is, adjust the timing time.
VD3 is a protection diode to prevent the reverse voltage of the relay coil from breaking down when VT is turned off. Automatic timing control can be achieved by connecting the A and B terminals of the relay contacts in series to the amplifier (or printer) power supply circuit. No external resistor R0 is required on the small printed board of the music integrated circuit.
- DIY a simple fire alarm
- Peripheral circuit of automotive motor controller power supply chip
- Introduction to the internal structure of the Delta winding motor
- Manual automatic air compressor control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- IGBT modules block overcurrent by controlling the gate
- Hydraulic control circuit design and analysis
- Temperature control circuit design and analysis
- Multi-channel patrol detection control circuit a
- Simple timing control circuit
- fire smoke control circuit
- Photoelectric tracking control circuit
- Chicken farm photoelectric control circuit
- Boiler control circuit
- One of the long delay circuits using integrated circuits
- Timer circuit that displays time using light dots
- Timer using Miller integrator
- long timer
