Echo signal processing circuit PT2399
Source: InternetPublisher:ghaytweyhtoo Keywords: signal processing circuit coupling circuit audio signal Updated: 2020/08/04
Shown is an echo signal processing circuit PT2399. It is mostly used in digital audio processing circuits, such as karaoke circuits.
In this circuit, the microphone signal is sent to the @ pin of PT2399 through the RC coupling circuit for delay processing inside the IC. The delayed audio signal is output by
the @ pin and at the same time from the output Then take a part of the signal and send it to the @ pin through the 0 k(l resistor for secondary delay processing. This will cause
the output signal to have multiple delays. It is like the reverberation effect of the sound in the valley.
- Design and analysis of a simple zero-crossing power regulator circuit
- Using CD4017 to form an analog pendulum circuit
- timer call circuit
- Integrated circuit sampling amplification circuit diagram
- Senlan BT40 multi-unit proportional linkage
- Simple stepless speed fan circuit
- Electronic disinfection cabinet circuit
- Rongsheng brand BCD-190 refrigerator circuit
- Yangzi brand BCD-212, BCD-230 refrigerator circuit
- Monolithic integrated circuit radio
- Household appliances remote control circuit
- Multi-channel surround sound audio signal processing circuit
- Typical digital audio signal processing circuit AD1885
- Digital signal processing circuit (DSP) block diagram
- transistor audio signal amplifier
- audio signal control circuit
- Two-channel audio signal conditioning circuit
- Equivalent circuit for treble boost
- Low power audio signal amplifier circuit
- TIL186-1/TIL186-2/TIL186-3/TIL186-4 AC input optical coupling circuit
