Wide dynamic range mixing circuit
Source: InternetPublisher:赔钱虎 Keywords: Wide dynamic range mixing circuit field effect transistor BSP Updated: 2021/02/15
Shown is a wide dynamic range mixing circuit . It uses two symmetrical field effect transistors and input and output transformer coupling methods
. The RF signal input end is equipped with three transformers (Ti, T2, T3), which are symmetrically added to the deep electrode of the II field effect transistor, and the local oscillator signal
is simultaneously added to the gate of the field effect transistor . The output stage forms a push-pull type and has a frequency selection function. The frequency selection circuit resonates at the intermediate frequency (20.6 MHz).
The input transformer turns the single-ended input (50n impedance) into a balanced output (200n impedance). The circuit features high dynamic range, but
the voltage gain is less than 1.
- Using CD4017 to form an analog pendulum circuit
- Commonly used supporting equipment for general frequency converters
- AM FM IF amplifier integrated circuit LA1201
- cooking timer circuit
- Circuit diagram of Rongsheng CFXB1, 3 and 4 double lamp thermal insulation automatic rice cooker
- Triangle, Yuanling, Gold CFXB type double lamp rice cooker circuit diagram
- Relay power saving circuit 2
- Triangle CRJ120-A multifunctional non-stick electric hot pot circuit diagram
- Color TV adds AV output socket
- Amplifier DIR1703+PCM1738 DAC PCB circuit diagram
- Bone hyperplasia treatment circuit
- Pulse therapy circuit
- Particle clogging alarm circuit of wheat seeder
- AC voltmeter
- Domestic KD8041 integrated phase locked loop
- Crabo oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- color discrimination circuit
