Bidirectional frequency conversion circuit
Source: InternetPublisher:D先生 Keywords: Frequency conversion circuit BSP transformer amplifier Updated: 2020/07/07
Shown is a bidirectional frequency conversion circuit . In the receiving state (RX), the signal received by the antenna enters the band-pass filter (BPF), and
the signal is added to the source (s) of the field effect transistor VT1 through the filter. The local oscillator signal is added to the gate of VT1, and the drain (D) of VT1 is connected to the primary winding of the intermediate frequency transformer. The primary winding of the intermediate
frequency transformer Tl resonates with the parallel capacitor at the intermediate frequency frequency. It outputs the difference signal after VTL mixing
. In the receiving state, the control terminal causes VD2 to be forward-biased and conductive, and the intermediate frequency signal is output through VD2, and then output through the transistor filter and the bidirectional
intermediate frequency amplifier .
When sending a signal, the control terminal is ov, VD1 is turned on, and the intermediate frequency signal is added to
the winding of the intermediate frequency transformer through the amplifier, crystal filter and VD1. The path of the local oscillator signal remains unchanged. The signal is input from the drain of VT1, and the source (s) output is then
sent to the antenna
through the bandpass filter and transmit amplifier (TX) to transmit the signal.
- How to use BME680 to design a smart home control center
- DIY a portable Bluetooth speaker
- Electric oven temperature controller circuit diagram
- Lihe ESA-25 temperature-adjustable electronic crock circuit diagram
- Tube amplifier CS8412+PCM63 classic design (power supply part) circuit diagram
- Minsk brand MNHCK-22 refrigerator circuit
- answering machine circuit
- Delta VFD-P inverter typical application circuit
- Water and electricity saving faucet circuit 2
- TV automatic frequency control circuit
- Electronic thermometer circuit
- Fish farming thermostatic control circuit
- Rural vegetable greenhouse lighting circuit
- Biogas concentration detection line
- AC voltmeter
- Diode square rate detection circuit
- Amplitude modulation circuit composed of MC1496
- Series crystal oscillator
- Broadband high frequency power amplifier circuit
- Power phase sequence display circuit
