Interface circuit composed of 8051 single chip microcomputer and 74LS165
Source: InternetPublisher:Lemontree Keywords: Microcontroller Updated: 2024/07/19
The figure below shows the interface circuit between 8051 microcontroller and 74LS165. The serial port of 8051 microcontroller works in mode 0, which is synchronous shift register input/output mode. The data received/sent is 8 bits, with the low bit first, and there is no start bit, parity bit and stop bit.
Serial data is input from RXD (P3.0), and the shift clock is output from TXD (P3.1). Port line P1.7 is used to control the working state of 74LS165. When P1.7 outputs a low level, 74LS165 puts parallel data into the register; when P1.7 outputs a high level, 74LS165 works in a serial shift state under clock control, and data is shifted into the 8051 microcontroller through RXD (P3.0).
- How to use the GPS module of STM32F103C8 to obtain location coordinates
- Computer USB port to mobile phone interface conversion circuit
- Interface circuit between 51 single chip microcomputer and MAX7219
- Make a capacitive soil moisture sensor using ESP32
- Serial debugger circuit implemented with several discrete components
- Improvement of microcontroller-driven piezoelectric buzzer
- Circuit principle and production of dot matrix Chinese character LED display
- Microcontroller test board circuit 1
- a watchdog circuit
- 815 motherboard
- PCF8591 hardware interface (circuit diagram pin diagram)
- Analysis of internal reset circuit diagram of microcontroller
- Special ultrasonic collision avoidance warning design for reversing
- Minimum system interface circuit based on AT89C52 microcontroller
- A microcontroller infrared asynchronous communication port circuit diagram
- Use MC34063 as a 12-volt programming power supply for single-chip microcomputer
- Multi-channel DA and microcontroller optical and electrical interface circuit
- Monitoring of 8048 microcontroller by WMS7705
- Interface between LCD 7-segment display and microcontroller
- Microcontroller remote key input circuit
