Single-phase active energy meter wiring with current transformer
Source: InternetPublisher:奥特man123 Keywords: Wiring current transformer energy meter Updated: 2021/01/27
The diagram shown above is the jump A type wiring method. Its characteristic is that terminals 1 and 3 of the electric energy meter are connected to the power supply, and terminals 2 and 4 are connected to the load
. Shown is slide-in wiring. Its characteristic is that the terminal numbers of the electric energy meter are connected in sequence, that is, terminals 1 and 2 are connected to the power supply and terminals
3 and 4 are connected to the load. When the current in the circuit under test is very
large and the rated current of the electric energy meter cannot meet the measurement requirements,
the method of distributing a current transformer can be used for measurement. The wiring of single-phase active energy meter
with current transformer is shown in Figure 15-11. At this time, the current coil of the electric energy meter
is no longer in series with the load circuit, but
is connected to the secondary winding of the current transformer. The primary winding of the current transformer is
the load line (power line) being measured . Special attention should be paid to the fact that the same terminals of the two windings of the current transformer
and the same terminals of the two coils of the electric energy meter cannot be connected incorrectly , otherwise the electric energy meter
may reverse.
- Driving circuit of switching power supply field effect tube
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Basic connection circuit of signal and power supply composed of ISOll3
- Simple and practical LED lamp driving circuit
- LED Driver ZD1680
- How to use SBR to improve power conversion efficiency
- Homemade low-power UPS
- Integrated regulated power supply with continuously adjustable output voltage
- Electric bicycle battery charger circuit
- Converting a lithium battery charging board into a constant voltage and current charger
- How to connect the components in PCB?
- 220V welding machine wiring circuit diagram
- Anti-serial mode interference wiring for automated instruments
- Zinc oxide arrester wiring a
- Lightning protection wiring for 300 to 1500kW direct generatorsa
- Y, y connected transformer lightning protection wiring
- Wiring of lightning protection network on the roof of a multi-story residential building
- Wiring b when leakage protector in TT system supplies single-phase load
- Use two single-phase power meters to measure the power connection of a three-phase three-wire circuit
- Voltage transformer VV junction box commutation switch access circuit
