Zinc oxide arrester wiring a
Source: InternetPublisher:武林萌主 Keywords: Wiring arrester BSP vacuum circuit breaker Updated: 2020/01/05
High-voltage zinc oxide arrester, also called high-voltage zinc oxide varistor, has
the advantages of small size, light weight, and good overvoltage protection performance. It is widely used for overvoltage protection in vacuum circuit breaker operation.
(1) Wiring of zinc oxide arrester
The zinc oxide arrester should be connected to the pile head under the circuit breaker and as close as possible to the protected equipment. Its wiring is
shown in the figure. In the figure, FP is a zinc oxide arrester. QF is a vacuum circuit breaker .
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Driving circuit that controls LED brightness using PWM signal
- The constant current source composed of two transistors can drive high power
- Miniature polarity reversal power supply using MAX1721
- Boost drive circuit composed of RT8450
- An ultra-low output voltage regulator
- 0.7~24V continuously adjustable current limiting power supply
- MIC4680 constant current charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Set timing circuit when power is on
- soil content measurement circuit
- Fish pond oxygenation reminder circuit
- Fish farming thermostatic control circuit
- Straw returning to field crusher circuit
- AC voltmeter
- collector amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Audio function generator composed of ICL8038
- Wireless microphone circuit
