Leakage current protection circuit
Source: InternetPublisher:酷到被通缉 Keywords: Protection circuit leakage current current protection current transformer Updated: 2020/11/20
The leakage current protection circuit is a traditional electromagnetic tripping device. It directly accepts the signal from the zero-sequence current transformer and has high sensitivity
. Generally, boron uses a polarized electromagnet and can operate when the leakage current reaches 30mA. When there is no leakage current, the permanent magnet of the leakage release will
attract the armature and it will be in normal working condition. When the protected circuit leaks to the ground, the current input from the secondary winding of the zero-sequence current transformer to the tripper coil
generates magnetic flux, which offsets the magnetic flux of the permanent magnet within half a cycle, and the armature is released by the tension of the spring. , the tripper operates and
the relay contacts are connected or disconnected within 0.1s. Adjust the spring so that there is a certain gap between the armature and the yoke, then the operating current can be adjusted.
- Tutorial for building a remote-controlled Arduino Air-Boat
- A small improvement on the ordinary refrigerator motor starting circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Using P110C to control 6 DC motors simultaneously
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of a four-bit remote control component capable of remote reset
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Home wireless burglar alarm circuit
- Infrared detection alarm
- Password type motorcycle anti-theft device
- Resistive Neutral Leakage Protection Circuit
- Three-phase motor phase failure transistor protection circuit
- Overvoltage and overcurrent protection circuit
- Stabilized power supply undervoltage protection circuit
- Thyristor overcurrent protection circuit 5
- Thyristor type overcurrent protection circuit 3
- Thyristor overcurrent protection circuit one a
- Mains undervoltage and overvoltage protection circuit 5
- Mains undervoltage and voltage loss protection circuit
- Water resistor anti-speed protection circuit
