Water resistor anti-speed protection circuit
Source: InternetPublisher:酷到被通缉 Keywords: Protection circuit BSP generator Updated: 2021/11/11
In order to prevent overrun accidents of small generators , water resistor energy dissipation measures can be used to transfer the energy of the unit before sudden load shedding
to the water resistor, thereby stabilizing and suppressing the rotation speed. The anti-flying protection circuit
using water resistors is shown in Figure 7-13.
When load shedding or other accidents occur in the generator, the circuit breaker QF trips (generally generators are equipped with over-current and over
-voltage protection devices), its normally open auxiliary contact closes, the contactor KM is electrically closed, and its main The contact is connected to the water resistor . At the same time, the electric
bell HA will sound an alarm, and the person on duty can slowly shut down the machine.
- Design and selection of electric control valve system drive
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Use your smartphone to turn on/off the power in your home
- How to Make a Simple Chicken Incubator
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Temperature control circuit design and analysis
- Do-it-yourself trial production of phase failure protection device
- Electric vehicle battery charging protection circuit
- Home wireless burglar alarm circuit
- Homemade short circuit alarm device
- strain sensor
- Excellent performance household inverter power supply circuit
- Inpatient pager circuit
- Physiotherapy ventilator circuit
- Agricultural spraying and insecticide control circuit
- Poultry warming temperature control circuit
- Simple AGC circuit in transistor radio
- Diode square rate detection circuit
- Wien bridge oscillator circuit
- superheterodyne radio circuit
