Plastic sealing machine circuit diagram
Source: InternetPublisher:兰博 Keywords: Relay Updated: 2024/10/15
When K1 is just turned on, KZ is powered on and works. Since the voltage of C2 is very low, BG is not conducting and the relay is energized. When C2 is charged to a certain level, BG is conducting, SCR is conducting, the relay power-off contact is disconnected, and heating stops. After K1 is disconnected, the power on C2 is discharged through D2, and the next cycle is ready. Adjusting W can change the working time of the sealing machine. In order to improve the reliability of the circuit, D3 increases the BG emitter voltage.
- Share a solar beacon circuit
- How to Make a Pet Robot
- The production of ultra-low-cost anti-theft system based on Blues wireless note card
- Working Principle and Production of TV Scanning Demonstrator
- How to use the MP3 player from CATALEX
- Input and output polarity reversal circuit composed of MAX660
- How to use ultrasonic sensors to make a simple nucleic acid sampling machine
- Homemade Micro AC Welding Machine
- A detection circuit with keen hearing
- Laser adjustable constant current drive circuit
- Liquid level relay drain wiring diagram
- Light control switch circuit
- Multifunctional environmentally friendly circuit
- Relay fixed time overcurrent protection circuit b
- Relay power saving circuit 5a
- Relay power saving circuit 2
- Interface circuit between power supply coupler and relay
- Remote control line a
- One of the circuits that uses thermistors to prevent relay contact competition
- Current transformer multi-function protection circuit a
