NE555 exponential voltage controlled oscillator circuit diagram
Source: InternetPublisher:两手空空 Keywords: voltage controlled oscillator circuit diagram NE555 oscillator circuit Updated: 2020/06/05
The F/V conversion linearity of general controlled oscillator circuits is poor. This VCO circuit uses a voltage-controllable current source, as shown in the figure below: it can significantly improve linearity.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- The constant current source composed of two transistors can drive high power
- Miniature polarity reversal power supply using MAX1721
- Adjustable regulated power supply with current limiting protection
- Power supply circuit that can reduce LM317 ripple
- Homemade low-power UPS
- Car power 1.5V-12V six-speed converter
- 0.7~24V continuously adjustable current limiting power supply
- USB power socket using the car battery
- Low phase noise voltage controlled oscillator circuit b
- Acousto-optic digital level detector circuit diagram
- Use NE555 to make a two-button touch light switch (1)
- Triangular wave and square wave generator circuit diagram installed with NE555
- Ne555 light control street light circuit diagram
- Low frequency voltage controlled oscillator circuit
- Pulse width modulation switching regulated power supply circuit diagram composed of NE555
- Linear voltage controlled oscillator circuit diagram
- Voltage controlled oscillator circuit diagram with output double limiting
- Voltage controlled oscillator circuit diagram with exponential characteristics
