Use NE555 to make a two-button touch light switch (1)
Source: InternetPublisher:失踪的猫 Keywords: switch touch type NE555 time base circuit Updated: 2020/03/02
The circuit of the double-button touch light switch made with NE555 is shown in Figure 3-2. The circuit
consists of touch electrodes, time base integrated circuits and bidirectional thyristor circuits.
The 220V alternating current is a simple capacitor step-down half-wave rectification and voltage stabilizing circuit composed of Cl, C2, VDI, and VD2 .
After power on, a DC voltage of about 12V can be obtained at both ends of C2 for the time base circuit . When you need to turn on the light, just touch
the "open" electrode piece M1 with your hand. The clutter signal induced by the human body is injected into the trigger terminal 2 of the time base circuit A, setting the time base circuit, and
the output terminal 3 outputs a high level. Therefore, the thyristor VS can obtain a positive trigger current and turn on, and the lamp H emits light when energized. At this time,
the LED also emits light to indicate the working status of the switch . When you need to turn off the light, just touch the "off" electrode piece M2 with your hand. The clutter signal induced by the human
body is injected into the threshold terminal 6 of the time base circuit, the time base circuit A is reset immediately, and the output terminal 3 outputs
low level. vs loses the trigger current. When the alternating current crosses zero, it turns off, the lamp H goes out, and the LED also goes out.
- Build a Bluetooth-controlled wireless scoreboard
- Audio level LED and digital dual display circuit
- Digital level display (CD40147, CD4511)
- Circuit diagram of game score display using 7-segment LED
- Musical doorbell without buttons
- Chandelier brightness controller circuit using thyristor
- Large light emitting diode display circuit
- Fluorescent lamp electronic ballast circuit 11
- Fluorescent lamp dimming circuit composed of thyristors
- Small current anti-theft alarm circuit
- Power phase failure display circuit
- Voice recording and playback circuit
- NE555 exponential voltage controlled oscillator circuit diagram
- Very simple voltage multiplier circuit block diagram
- Make strobe light with NE555
- Use NE555 to make light-controlled flashing warning lights
- Use NE555 to make a two-button touch light switch (2)
- Overvoltage and overcurrent protection circuit diagram using NE555
- Constant current timing charger circuit diagram using NE555
- Stable output DC and DC converter circuit diagram composed of NE555
