Variable frequency transistor oscillation circuit
Source: InternetPublisher:闪电杰克 Keywords: Transistor oscillation circuit BSP emitter Updated: 2020/07/13
Shown is a variable frequency transistor oscillator circuit
. This circuit is mainly
composed of a transistor oscillator, a crystal resonant circuit, a varactor diode, and an output amplifier. It can usually be used to make high-frequency transistor oscillators. The inductor LP of the transistor
in the circuit 30 MHz is connected to the emitter circuit of VT1. It is connected in parallel and then connected in series with the varactor diode, and then
connected in series with the 75 p capacitor between the collector and emitter of VT1 . The amplifier composed of VT2 and VT3 amplifies the oscillation signal and
outputs it from the collector of VT3. The control voltage of the varactor diode changes between 4-+-6 V.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- Analysis of the basic principle of measuring resistance by bridge method
- What are the types of commonly used batteries?
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Beautiful crown wreath made with LED
- What is the difference between high-side and low-side resistive current sensing
- LED Night Light
- Circuit diagram of a differential amplifier circuit
- FL52C4 induction electronic greeter
- Analysis of rectifier circuit types and principles
- Smoking Cessation Circuit
- Agricultural temperature control circuit
- Soil water shortage prompt circuit
- Mixer built with analog multipliers
- Amplitude modulation circuit composed of MC1496
- Voltage series negative feedback amplifier circuit
- common emitter amplifier circuit
- Wireless microphone circuit
- Home appliance repair signal generator circuit
