FM radio circuit of DA-101 chip
Source: InternetPublisher:笑流年 Keywords: FM radio CPU Updated: 2020/11/24
FM radio circuits use different radio chips, and their working principles are also slightly different. The figure shows an FM
radio circuit using the DA-101 chip. In the radio state, the socket of the earphone serves as the antenna of the FM radio circuit. The FM radio program signal received by the antenna is sent to the @ pin of U13 through the coupling capacitor
c58. This signal is a radio frequency carrier wave. High-frequency amplification, mixing, intermediate frequency amplification, frequency identification and other processing are carried out in U13, and
the audio signal is demodulated and output by the ⑤ and @ pins, and then sent to the digital decoding chip for processing. The radio circuit U13 k{JI operates Under the control of the CPU
, the Izc bus control signals (DATA, CLK) of the CPU are added to the ④ and ⑤ pins of U13 respectively. The radio power supply control
signal of Ul3 is added to the gate of VT5 by the control signal of the CPU , and is supplied to the power supply of U13 through VT5 control, thereby achieving
the purpose of controlling the radio.
- Share a mini piano circuit
- Using TDA2822 to do direct coupler output experiment
- Making a Simple Tube FM Radio
- 6BX7 10W bile duct amplifier
- Audio power amplifier circuit powered by a single power supply using LM1875
- LM4903/4905 differential input audio amplifier circuit
- Protection circuit and maintenance of household audio power amplifier
- LM4906 Audio Power Amplifier Circuit
- Dual power supply audio power amplifier circuit composed of LM4730/LM4731
- Application of BTL power amplifier circuit composed of LM3886
- Crystal oscillator PCB design considerations
- Microprocessor crystal oscillator circuit
- MP3 machine CPU and decoder chip circuit using SPCA7550 chip
- CPU and decoding chip memory, SD memory card socket interface circuit
- Recorder graphic equalizer drive circuit
- CPU power supply circuit using RT9245 chip
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- HM2068 CPU operating mode application circuit
