How multi-resonators workb
Source: InternetPublisher:同住地球村 Keywords: Resonator BSP switch Updated: 2021/06/24
Figure (a) shows the situation when switch sl is turned off. Positive voltage is added to the base of VT2 from the power supply through R2 , causing V-12 to conduct. At this time,
the dotted line in the circuit is the current charging capacitor C2.
Then make the switch sl close t as shown in figure (b). Since the capacitor C2 has been charged at this time, the voltage is reduced to o. Therefore, at the moment when the switch is closed,
it is equivalent to adding negative voltage to the base of VT2, causing VT2 to cut off. The direction of the dotted line in Figure (b) is the direction in which the charge of capacitor c7 is discharged.
Then the base voltage of VT2 changes from negative to positive, and then VT2 is turned on again.
- Which one is better, NPN or PNP transistor?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- How does RCCB work?
- Build a musical fountain using Arduino and sound sensor
- Introduction of TDA4863J/4863AJ TV field scanning IC
- LED Night Light
- LED Bicycle Lights
- Experiment and production of NE555 time base integrated circuit
- Agricultural small tractor lighting circuit
- Farmland irrigation automatic control circuit b
- DC ammeter
- AC voltmeter
- Diode square rate detection circuit
- ring amplitude modulation circuit
- Parallel crystal oscillator
- Crabo oscillator circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
