The second frequency conversion circuit of the satellite receiver
Source: InternetPublisher:睡不醒的小壮 Keywords: Satellite receiver frequency conversion circuit intermediate frequency signal Updated: 2020/08/17
The second frequency conversion circuit of the DBS series satellite receiver is shown in the figure. This circuit has a simpler structure than the above circuit. The first intermediate frequency signal
first passes through a 950-1 450 MHz band-pass filter to filter out interference other than the first intermediate frequency. It then goes through two stages of RF amplifiers for wide-band low-noise
amplification, and then mixes the frequency with the signal from the second local oscillator. After frequency difference, the second intermediate frequency signal is obtained. The intermediate frequency signal is amplified by AGC
to stabilize the signal amplitude, and the buffer and band-remote filter are used to extract the intermediate frequency signal. The frequency of the bandpass filter is 512±13.5 MHZ . It
is fixed, so the performance of suppressing adjacent channel interference is not as good as the circuit mentioned above, but because the intermediate frequency it chooses is relatively
high (512 MHz) , the ability to suppress image frequency interference is relatively strong. The IF signal is demodulated after multi-stage amplification. This circuit uses a PLL
(phase-locked loop) demodulation circuit. The phase-locked loop demodulation circuit is not sensitive to the amplitude changes of the signal, so a special limiting circuit can be omitted. The AFC
switch is controlled by a microprocessor (CPU) for easy debugging.
- Peripheral circuit of automotive motor controller power supply chip
- Build a glove-controlled robotic arm
- DIY an electromagnetic levitation device
- A small improvement on the ordinary refrigerator motor starting circuit
- Simple phase failure protection circuit composed of intermediate relay
- Design and production of radio remote control fan stepless speed regulator
- Design and production of wireless multi-location control switch circuit
- Design and analysis of voice control circuit
- Design and manufacture of three-phase motor protection circuit
- Design and production of no-load automatic power-off device for household power supply
- Differential amplifier emitter negative feedback gain control circuit
- Photocell trigger control circuit
- Ringtone control circuit
- Electromagnet control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- High-rise residential walkway lighting control circuit
- PLC chain alarm control circuit used in production process
- Neon light control circuit
- Galanz rice cooker control circuit
- 28MHz frequency conversion circuit
