voltage follower
Source: InternetPublisher:清宁时光 Keywords: Voltage follower emitter dual power supply Updated: 2020/08/22
Shown is a voltage follower , which uses a double emitter follower circuit and is mainly used in voltage output circuits. The signal
is input from the base of VT1 and is directly coupled to VT2 by its emitter . VT2 also has the structure of an emitter output device, and the signal is output by the emitter . VT3 is connected
as a constant current source, and the circuit is powered by dual power supplies to meet the requirements of DC operation, and can obtain high input impedance and low output impedance.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Build a glove-controlled robotic arm
- How can we make the robot move precisely on a predefined path?
- What is a RADAX motor?
- A small improvement on the ordinary refrigerator motor starting circuit
- A small improvement to the temperature and water level indicator alarm
- Design and production of radio remote control fan stepless speed regulator
- Infrared blocking alarm device
- Motorcycle anti-theft device circuit design
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Simple timing control circuit
- fire smoke control circuit
- Photoelectric tracking control circuit
- Digital camera flash control circuit
- Infrared voice control circuit
- Multi-pole leakage protector circuit a
- Highly stable sinusoidal oscillation circuit
- High reliability carrier oscillation circuit for emitter
- SSM-2125 dual power supply application
