Highly stable sinusoidal oscillation circuit
Source: InternetPublisher:containsmachine Keywords: Oscillation circuit oscillator carrier emitter Updated: 2021/01/10
Shown is a high-reliability carrier oscillator for the emitter . This circuit is mainly
composed of a field effect tube oscillator , amplifier and output circuit . It can generally be used in the carrier oscillation circuit of the emitter . The oscillation circuit is composed of a field effect transistor VT1 and an LC parallel resonant circuit connected to the gate. The oscillation signal is output from the source of VT1.
- Datasheet/Pinout/Technical Specifications of LMC555
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Working principle/advantages/disadvantages/size of optical fiber
- How does RCCB work?
- Why use PWM? What are its advantages?
- Summary of knowledge points of multiplexer
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Experiment and production of NE555 time base integrated circuit
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Circuit diagram of a differential amplifier circuit
- Patient call alarm circuit
- AM modulated low-power emitter carrier oscillator
- crystal controlled oscillatora
- Inductive three-point oscillator
- Bird call analog signal generator circuit
- Triangular wave oscillator using 2 operators
- One of the single-junction transistor time relay circuits
- Gas-sensitive alarm circuit three
- Upper and lower symmetrical negative feedback mode field effect transistor power amplifier 01
- Emitter amplitude modulation circuit
