Water heater electronic ignition circuit
Source: InternetPublisher:风向西瓜 Keywords: water heater ignition circuit switch Updated: 2021/05/29
Shown is the water heater electronic ignition circuit . When the faucet is opened, switch K turns on the 3V battery. Since C2 takes time to charge, VT6 is in a cut-off state. The power supply charges C3 at the same time. The charging turns on VT7 and VT8, which
activates
the gas supply (gas) solenoid valve BK.
The winding is energized, the gas valve is opened, and gas supply begins.
- Tutorial on making your own remote-controlled robotic arm
- Design of an autonomous plant watering system using ATtiny85
- A small improvement to the temperature and water level indicator alarm
- Manual automatic air compressor control circuit
- Motor control circuit for starting and running without phase loss
- Add one more component to improve the phase failure protection function
- Hydraulic control circuit design and analysis
- Design and analysis of voice control circuit
- Electric vehicle battery charging protection circuit
- Vibration anti-theft alarm circuit
- Rural vegetable greenhouse lighting circuit
- Electromagnet control circuit
- Using 74LS244 to expand 24-channel input interface circuit
- How multi-resonators worka
- Astable Multivibrator
- Circuit schematic diagram of Y-△ starting three-phase induction motor
- Single pulse signal generating circuit d
- Keying pulse signal generation circuit
- 5V to 2.5V voltage stabilizing circuit
- One of the long delay circuits using integrated circuits
