5V to 2.5V voltage stabilizing circuit
Source: InternetPublisher:无人共我 Keywords: Voltage stabilizing circuit power supply PWM switch Updated: 2021/07/22
Shown is a 5v to 2.5V voltage regulator circuit on a computer motherboard . It can be seen from the circuit that this circuit is a power supply
circuit with the power management chip RT9202
as the core . RT9202 is a switching pulse generation circuit. After the 5v power supply is supplied , the circuit starts to oscillate. Pins ② and ④ respectively output PWM signals
with opposite phases , so that The two-field effect transistors MU and ML work alternately to convert 5V DC into a pulse signal, which is
filtered by LC and turned into a 2.5 V DC voltage to power some circuits on the motherboard.
- Practical and convenient fax machine power supply control circuit
- What kind of circuit is a voltage regulator circuit?
- Driving circuit that controls LED brightness using PWM signal
- LNK304 non-isolated LED light string driver circuit
- Low cost and high performance LED constant current power supply
- Integrated regulated power supply with continuously adjustable output voltage
- 0.7~24V continuously adjustable current limiting power supply
- Electric bicycle battery charger circuit
- Production of backup power supply for cordless phone
- Adjustable voltage regulated power supply circuit
- Classification analysis of PWM control
- NE555PWM pulse width modulation circuit
- Timer circuit for blasting
- Instantaneous water heater automatic constant temperature experimental circuit diagram
- 8-way switching input interface circuit
- On and off states generate fixed-width pulse circuit
- 5V to 2.5V voltage stabilizing circuit
- AC adapter circuit
- PWM signal generation circuit diagram
- Ultra-small PWM, DC-DC booster circuit diagram
