DC voltage-current conversion circuit
Source: InternetPublisher:containsmachine Keywords: Conversion circuit DC voltage current conversion PLUSMN Updated: 2020/10/12
Shown is a DC voltage-current conversion circuit that can convert a DC voltage of ±10 V into a current of ±1 mA. The input
voltage is added to the input terminal of LM301A, and is amplified and output by the composite transistor. After being amplified by the operational amplifier TL080,
the current signal is output through the composite transistor. During operation, the ±10 V regulated power supply provides a bias current (2 mA) to the input terminal through a current-limiting resistor, and the bias current to the output terminal
is provided by the operational amplifier and composite transistor.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Car ice warning circuit sharing
- How to remotely control devices using ESP8266 and LPC2148
- A small improvement to the temperature and water level indicator alarm
- DC motor drive circuit composed of L293D
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Design and analysis of wire control circuit
- Design and production of wireless multi-location control switch circuit
- Flashing wall light control circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Simple timing control circuit
- Schematic diagram of motor PLC control circuit
- Multi-pole leakage protector circuit a
- CPU input and output and memory control circuit
- Typical operation display circuit
- Photoelectric output control circuit
- DC power amplifier with fault indication
- Application circuit of TDA2040(A)-dual power supply operation
