Photoelectric output control circuit
Source: InternetPublisher:Lemontree Keywords: Optoelectronics control circuits output control optoelectronic devices Updated: 2020/11/05
Optoelectronic devices are generally composed of light-emitting diodes and photosensitive transistors,
which are also called photoelectric couplers. The figure shows the
output control circuit using a photodetector , which is the most basic circuit composed of photoelectric
devices.
Threshold levels can be set for the voltage dividing points of Ri and M.
The distance between the light-emitting diode and the photosensitive transistor of this circuit can be in the range of 0 to 5 degrees, and it can detect direct
light or reflected light. Change the state of light and no light (or light blocking) into an electrical signal
output, and add it to the load ItL.
- Tutorial on making your own remote-controlled robotic arm
- Controlling LEDs with Node-RED in Raspberry Pi
- How to build a simple tachometer using an infrared reflectance sensor
- How can we make the robot move precisely on a predefined path?
- Design and analysis of wire control circuit
- Design and analysis of the principle of automatic power-off switch during power outage
- Light-controlled circuit design and analysis
- Temperature control circuit design and analysis
- Guanghua brand anti-theft doorbell electronic lock circuit
- Password type motorcycle anti-theft device
- Photoelectric remote control power switch circuit diagram
- Printing machine photoelectric paper break detection circuit
- Photoelectric-acoustic conversion circuitb
- Photoelectric control digital tube display circuit
- Photoelectric control lighting circuit using photosensitive sensor
- Photoelectric control relay circuit
- Photoelectric motor speed signal generation circuit
- Frequency selective photoelectric relay circuit diagram
- Darlington type phototransistor self-locking photoelectric control relay circuit diagram
- Photoelectric insect killer circuit
