Electric kettle automatic power off controller circuit diagram
Source: InternetPublisher:jikai233 Keywords: Automatic power off controller circuit diagram contacts Updated: 2021/01/07
The circuit working principle of this device is shown in the figure. First, use epoxy resin to dip a sheet-shaped positive temperature coefficient switching thermistor RQ on the electric kettle. Connect the two ends of RQ to the ① and ② pins of L SE , insert the kettle into the power socket CZO, and press Turn off the power switch S. At this time, due to the low temperature of the water in the kettle, the resistance of RQ is small (<50K), so the ④ pin of LSE outputs high level, the relay J immediately closes, and the normally open contact j closes. The electric kettle works when powered on. After releasing your hand, the relay J contact is self-protecting. Once the water boils (100°C), the resistance of RQ rises step by step, much greater than 50K, which is equivalent to the circuit disconnection of pins ① and ② of LSE, so pin ④ of LSE outputs low level, J is released, and its contact j Disconnect completely cuts off the power supply of the electric kettle, allowing the owner to boil water without any worries when going out. Among them, RQ should use a switching thermistor with a positive temperature coefficient, and its Curie point is 100°C.
- The basic principles of power supply design. What are the key components of a power supply?
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Schematic diagram of car cigarette lighter to USB power port
- Practical and convenient fax machine power supply control circuit
- Basic connection circuit of signal and power supply composed of ISOll3
- Op amp power supply decoupling bypass measures
- Switching power supply circuit composition and function introduction of each part
- Homemade low-power UPS
- Converting a lithium battery charging board into a constant voltage and current charger
- How to Select Modular EMI Filters for AC-DC Converters
- Portable device charging power circuit design
- 3v to 5v circuit diagram
- Typical Reference Voltage and Power Supply Circuits
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- Circuit diagram of an automatic water level controller
- One of the transistor stabilized current power supply circuits
- CF1 (CF2) DC power supply circuit
- 555 music lantern controller circuit diagram
- Sequential timing controller circuit diagram
- Telephone automatic trial dialing controller circuit diagram
