Touchpad interface circuit (IBM ThinkPad T60)
Source: InternetPublisher:清宁时光 Keywords: IBM interface circuit touch Updated: 2020/06/23
Shown is the interface circuit ( IBM IlunkPad T60) connected to the touch panel . This circuit has two DC voltages of 3.3 V and Sv.
When the touch panel is controlled, the interface circuit receives the control signal from the capacitive transducer and integrated circuit on the touch panel, and sends it to the touch
panel management chip to identify and encode the touch panel control signal. If the touchpad interface circuit fails, the touchpad
control will be disabled.
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- How does a series arrangement of Zener diodes affect the electrical behavior?
- This article will tell you the hard requirements of operational amplifiers
- What are the types of commonly used batteries?
- What is a D flip-flop and how does it work?
- DIY a decorative lamp
- How does RCCB work?
- Tutorial on building a NOT gate using BJT transistors
- What is a Demultiplexer
- FL52C4 induction electronic greeter
- Temperature control interface circuit
- Interface circuit of card reading module
- Interface circuit of dot matrix LCD display
- Interface circuit between 4-wire resistive touch screen and ADS7846
- MAX225-RS232 multi-channel data interface circuit (driver-receiver)
- Interface circuit between CMOS and PMOS d
- Interface circuit between CMOS and PMOS c
- Interface circuit between power supply coupler and PLC
- Mechanical switch contacts and CMOS interface circuit
- Interface circuit for photosensitive device and TTL matching
