Interface circuit between 4-wire resistive touch screen and ADS7846
Source: InternetPublisher:国民男神经 Keywords: ADS interface circuit resistive touch screen BSP Updated: 2020/02/17
For 4-wire resistive touch screen with. Interface circuit of ADS7846 .
The ADS7846 chip contains analog electronic switches and successive approximation A/D converters. By switching the on-chip analog switch, connect the X+ (or
Y+) terminal to the positive power supply (‰), the x- (or Yr) terminal to the ground (CND), and connect the Y+ (or ) terminal
is connected to the input terminal of the A/D converter in differential form. When the pen touches different positions of the touch screen,
the voltage values input from the Y+ (or X+) terminal to the on-chip A/D converter are different. After the input voltage is converted by the on-chip A/D, the Y (or Output value, and the output value
has an approximately linear relationship with the stroke point position. Therefore, the output values X and Y (ie, coordinate values) of ADS 7846 can describe the position of the pen touch point on the touch screen
- How to identify common mode interference? Methods to eliminate common mode interference
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- The Importance and Ideal Model of Impedance Matching
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Datasheet/Pinout/Technical Specifications of LMC555
- How to calculate the value of capacitors in parallel?
- Working principle and truth table of JK flip-flop
- Causes of PCB deformation How to prevent circuit board bending and warping
- Tutorial on building a NOT gate using BJT transistors
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Homemade disinfectant circuit
- soil content measurement circuit
- Frequency modulator composed of NE566
- Amplitude modulation circuit composed of MC1496
- Inductive feedback oscillator circuit
- color discrimination circuit
- Color display circuit
- Motorcycle flash light circuit
- Sawtooth wave generator circuit (2)
- ADS7824 parallel interface circuit
