Frequency servo circuit block diagram
Source: InternetPublisher:无人共我 Keywords: Servo circuit Hall element Updated: 2021/04/18
Shown is the block diagram of the frequency servo circuit . At the beginning, the starting circuit adds a voltage to the Hall element , so current flows through Hl and
H2. At this time, due to the magnetic pole effect of the magnet, one of the Hall elements generates a voltage , which
provides current to the motor coil through the amplification of JC1 or IC2 . As a result, a magnetic field is generated that drives the magnet to rotate, and the rotor magnet begins to rotate. After starting to rotate, the starting circuit stops working.
- How to use a microcontroller to control a servo motor?
- Design and selection of electric control valve system drive
- How to choose the right level of integration to meet motor design requirements?
- Use your smartphone to turn on/off the power in your home
- Peripheral circuit of automotive motor controller power supply chip
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- A simple door handle touch alarm circuit
- What are the challenges in designing a permanent magnet linear generator?
- Design and analysis of the principle of automatic power-off switch during power outage
- Light-controlled circuit design and analysis
- Micro remote control receiving and control circuit
- Photocell trigger control circuit
- Ringtone control circuit
- Switching regulated power supply circuit
- Microwave oven control circuit
- sound control circuit
- Automatic tuning control circuit
- Automatic door detection control circuit
- Typical electronic volume control circuit
- Diamond differential input power amplifier power circuit
