Speed regulation by connecting resistors in series in the excitation circuit
Source: InternetPublisher:走马观花 Keywords: Excitation resistor speed regulation Updated: 2021/06/13
In order to change the main magnetic flux, a speed regulating resistor R is connected in series in the excitation circuit
, as shown in the figure. Changing the size of the speed regulating resistor R can change the excitation current, thereby changing the main magnetic flux, thereby
achieving speed regulation. This method of speed regulation can only reduce the magnetic flux and increase the speed.
- Design of an autonomous plant watering system using ATtiny85
- How can we make the robot move precisely on a predefined path?
- How to set up a cheap beam break sensor control distance scene using a reflector
- Manual automatic air compressor control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of wire control circuit
- Light-controlled circuit design and analysis
- Temperature control circuit design and analysis
- Infrared blocking alarm device
- A novel and practical power line anti-theft and cutting alarm circuit
- Photocell amplification control circuit
- Ringtone control circuit
- Digital camera flash control circuit
- Water dispenser double sheet control circuit
- Synchronous motor excitation device circuit
- DC electromagnet strong excitation quick release circuit
- DC electromagnet strong excitation fast pull-in circuit one a
- The armature series resistor starts a circuit that changes the excitation current speed regulation.
- Synchronous motor full voltage starting circuit
- Magnetic detection excitation circuit
