The armature series resistor starts a circuit that changes the excitation current speed regulation.
Source: InternetPublisher:elleny Keywords: excitation Updated: 2020/03/24
When the armature voltage of a DC motor remains unchanged, reducing the excitation current can increase the speed; increasing the excitation current
can reduce the speed.
The circuit layout is shown in Figure 3-192. This circuit still uses the starting method of stringing resistors in the armature loop, and the speed adjustment
uses the method of changing the excitation current.
In the figure, R is the starting resistor, which is also used as a current-limiting resistor during braking; the porcelain rheostat RP is used for speed regulation, which can be adjusted to
change the excitation current , thereby changing the speed of the motor; KMi is the energy consumption braking contactor; KM2 is the working contactor;
KM3 is the contactor for short-circuiting the starting resistor , that is, the accelerating contactor.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- The meaning and importance of circuit protection, common types of circuit protection
- Build a glove-controlled robotic arm
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- An automated model railroad layout project using a microcontroller
- Working principle of one Xipu STR soft starter controlling two motors
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Design and analysis of a four-bit remote control component capable of remote reset
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Infrared detection alarm
- Pyroelectric automatic door control circuit
- Micro remote control receiving and control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Car window control circuit
- Assembly line outage monitoring circuit
- Electromagnetic brake control circuit
- TLG-1-, 2, 3 type thyristor automatic excitation device circuit
- A starting circuit that reduces the voltage of the synchronous motor reactor and adds excitation according to the change of the stator current
- Non-excitation circuit of stepper motor
