Bird call analog signal generator circuit
Source: InternetPublisher:MartinFowler Keywords: signal generator analog signal generator circuit oscillator Updated: 2021/12/07
Shown is a bird call analog signal generator circuit. The circuit consists of six inverters CD4069 forming three oscillators .
The two inverters l and 2 of lcl form an ultra-low frequency oscillator. Its oscillation frequency is a fraction of a hertz. This signal is sent to
the counter The CLK terminal of IC2 has different configurations in the output terminals Q1-Q9 of IC2 according to the number of input pulses to control the subsequent fftj-tube
matrix. The inverters 3 and 4 of ICI form an audio oscillator and are used to generate audio signals. The non-inverters S and 6 of IC1 form a low-frequency oscillator.
The audio oscillator is controlled by the low frequency oscillator output signal, so the output of the audio oscillator is a modulated audio signal. The signal output by the low-frequency oscillator is sent to the audio oscillator
through C4 and one or more of B-RII . Whether 8~Rl1 is connected depends on
the on or off of the analog switches ES1~ES4, and ES1-ES4 is affected by Controlled by VD2-VD9.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- The Importance and Ideal Model of Impedance Matching
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- What are the classifications of filters?
- Diode-based clipping circuit
- Basic characteristics/working principles and application circuits of tunnel diodes
- Share a Motorola amplifier circuit
- Touch circuit design and analysis
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Bird call analog signal generator circuit
- Staircase wave signal generator circuit
- Several improved sawtooth wave generator circuits-capacitive feedback circuit
- Debugging various signal generator circuits
- Signal generator circuit diagram
- Voltage controlled oscillation signal generator circuit
- Simple signal generator and tester circuit
- 88 to 108MHz FM signal generator circuit
- Flowmeter excitation signal generator
- Second signal generator homemade LED digital clock
