Typical relaxation oscillator and its output voltage waveform
Source: InternetPublisher:张三叔 Keywords: Oscillator Output Voltage BSP Switch Updated: 2021/04/07
The sawtooth wave signal generator is actually an extension and application of the relaxation oscillator. The figure shows a typical relaxation oscillator . If
the input terminal of the operational amplifier switches between ten/- voltages, there will be a triangular wave signal at the output terminal. This feature can be used to form the required
oscillation circuit.
When the switch is switched to position 1, a negative voltage is applied, so The output is a positive slope voltage: when the switch is switched to position 2,
the output is a negative slope voltage. If the switch
switches back and forth at regular intervals, the output is
a triangle wave consisting of alternating positive and negative ramp voltages.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- In-depth analysis of energy losses in oscillation frequencies
- How does sand become chips?
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- What are the classifications of filters?
- DIY a decorative lamp
- Analysis of three simple electronic dice circuits
- How does RCCB work?
- Structural diagram and function of sliding resistor
- Excellent performance household inverter power supply circuit
- Smoking Cessation Circuit
- High-efficiency speaker circuit for rural stage
- Chicken supplementary light to increase egg production rate circuit
- Domestic KD8041 integrated phase locked loop
- Mixer built with analog multipliers
- Double detuned loop frequency discriminator circuit
- ring amplitude modulation circuit
- Fault signal trip circuit
- Digital stopwatch display circuit
