Broadband high frequency signal amplifier
Source: InternetPublisher:elleny Keywords: signal amplifier frequency band high frequency signal field effect transistor Updated: 2021/10/22
Shown is a wide-band high-frequency signal amplifier using a double-gate field effect transistor . The high-frequency signal is coupled by a two-stage transformer to filter
out the low-frequency signal, and then sent to the Gi of the field effect transistor. 02 is the gain control terminal. Field effect transistors have the characteristics of high input impedance and low noise
. The amplified signal is output from the drain D, which is connected to the output of the transformer. The primary part of the transformer is added as an interface. Two LC filter circuits
and a three-terminal voltage regulator provide DC bias for the drain of the field effect transistor.
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- How does a series arrangement of Zener diodes affect the electrical behavior?
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Causes and solutions for noise in digital Class D amplifiers
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Datasheet/Pinout/Technical Specifications of LMC555
- What is power factor and three ways to improve it
- What is the difference between high-side and low-side resistive current sensing
- Experimental circuit based on 4040 binary adder counter
- LED lights that “drain” battery power
- Balanced mixing circuit composed of two double-gate field effect transistors
- High frequency signal input switch circuit a
- Broadband amplifier circuit
- Broadband high frequency amplifier circuit
- Buffer amplifier with small back radiation
- Transistor Broadband Video Amplifier
- High frequency signal generator circuit
- Using field effect transistor crystal oscillator circuit with PN junction
- audio signal amplifier circuit
- Broadband multivibrator circuit
