Transistor Broadband Video Amplifier
Source: InternetPublisher:宋元浩 Keywords: transistor frequency band video amplifier common emitter Updated: 2021/12/14
Shown is a wide-band video amplifier using a common emitter and a common base , which is composed of two transistors. The video signal R is added to the base of the
common emitter transistor VT902. VT902 is connected as a common emitter amplifier, so it has a higher gain.
The output of the collector of VT902 is directly sent to the indigo emitter of VI901. VT901 is connected as a common base amplifier, so it has the characteristics of wide frequency
and amplification The final video signal is sent to the cathode of the picture tube from the VT901 collector output. This circuit gives full play to the characteristics of the two circuits, and the circuit is simple and
has good performance. Common emitter , common collector and common base amplifier circuits are the three most basic unit circuits in single-tube amplifiers, and all other amplifier circuits
can be regarded as their deformations or combinations. Therefore, it is very necessary to master the properties of these three basic unit circuits.
- What is a photocoupler and how to select and use one?
- How are diodes made using semiconductors?
- FPGA Features and Architecture
- Analysis of the working principle of CMOS/CCD image sensor
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Working principle/advantages/disadvantages/size of optical fiber
- Basic characteristics/working principles and application circuits of tunnel diodes
- Ceramic filter structure/working principle/characteristics/application
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- water saving circuit
- Touch switch power circuit
- Laser power circuit
- Transistor withstand voltage measuring instrument circuit d
- Transistor withstand voltage measuring instrument circuit a
- Bridge motor drive circuit
- Picture tube final video driver amplifier
- Three types of transistor amplification circuits and their characteristics - common emitter circuit
- Transistor common emitter circuit
- Common emitter circuit-slightly variable equivalent circuit
