Emitter coupled differential amplifier circuit
Source: InternetPublisher:狂妄火龙果 Keywords: Coupling differential amplifier circuit BSP resistor Updated: 2021/09/20
(1) Emitter coupling differential amplifier circuit
In the basic differential amplifier circuit, the symmetry of the circuit is relied upon to suppress zero point drift. The better the symmetry, the better the effect of suppressing zero point drift
. However, in fact, it is impossible for the circuit to be completely symmetrical, so the zero-point drift suppression of the basic differential amplifier circuit is greatly limited. The way to improve it is to connect a resistor
to the emitter of the basic amplifier circuit , as shown in the figure. The reason why the two bias resistors Rb12 and Rb22 can be eliminated
is because of the use of dual DC power supplies. Its working principle is briefly described below.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- How are diodes made using semiconductors?
- Analysis of the flow direction of transistor current
- Signal diode arrays/configurations, freewheeling diode operation
- What does a rectifier do? What is the process of rectification?
- This article will tell you the hard requirements of operational amplifiers
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- How does RCCB work?
- Summary of knowledge points of multiplexer
- Circuit diagram of an example of differential and integral circuits
- Electric massager circuit
- Smoking Cessation Circuit
- Physiotherapy ventilator circuit
- Agricultural spraying and insecticide control circuit
- Farmland irrigation automatic control circuit b
- Varactor Diode Frequency Modulator
- Diode square rate detection circuit
- base amplitude modulation circuit
- ring amplitude modulation circuit
- Fault signal trip circuit
