Circuit diagram of an example of differential and integral circuits
Source: InternetPublisher:念慈菴 Keywords: Differential circuit Integral circuit Updated: 2024/10/30
The differential and integral circuit diagram is shown below:
The differential circuit can convert a rectangular wave into a sharp pulse wave. The output waveform of the circuit only reflects the sudden change of the input waveform, that is, there is output only at the moment when the input waveform suddenly changes.
Differential circuits are mainly used in pulse circuits, analog computers and measuring instruments. They can obtain information contained in the leading and trailing edges of pulses, such as extracting time base standard signals.
Integral circuits are mainly used for waveform transformation, elimination of offset voltage in amplifier circuits, and integral compensation in feedback control.
- Signal diode arrays/configurations, freewheeling diode operation
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- In-depth analysis of energy losses in oscillation frequencies
- What are the classifications of filters?
- What are the parts of the fpga design process
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- How to calculate the value of capacitors in parallel?
- DIY a decorative lamp
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Digital number selection machine
- Narrow pulse forming circuit
- Voltage differential negative feedback circuit
- RC differential circuit
- Differential circuit
- Narrow pulse generation circuit using differential circuit
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
