Two-stage transformer coupled intermediate frequency amplifier circuit
Source: InternetPublisher:aerobotics Keywords: IF amplifier circuit transformer coupling BSP Updated: 2021/08/20
Transformer coupled multi-stage amplifier circuit. The circle shows the two-stage transformer coupled intermediate frequency amplifier circuit . Level 1 and level 2
are connected to each other via a transformer.
Transformer coupling has two advantages: first, because the transformer can only couple AC signals (that is, it can only change AC but not DC), so the static operating points of
the front and rear stages are also independent of each other; second, the transformer has an impedance conversion function. Use transformer coupling. The best impedance matching can be obtained between the front and rear stages
so that the preamplifier can output maximum power to the subsequent stage amplifier.
Disadvantages of the transformer coupling method: First, it cannot amplify signals with very low frequencies; second, the size and mass of the transformer are large and are not suitable for
miniaturization and integration.
Transformer coupling can be widely used in circuits such as low-frequency power amplifiers, intermediate-frequency amplifiers, and high-frequency amplifiers.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- Which one is better, NPN or PNP transistor?
- How does a series arrangement of Zener diodes affect the electrical behavior?
- How to identify common mode interference? Methods to eliminate common mode interference
- How to read resistor color codes? Resistor color codes illustrated
- What are the types of commonly used batteries?
- Working principle and truth table of JK flip-flop
- Simple Wired Spy Bug Circuit Built Based on IC741
- DIY a decorative lamp
- Analysis of three simple electronic dice circuits
- stuttering correction circuit
- Electric massager circuit
- soil content measurement circuit
- Peanut and melon seeds roasting machine circuit
- AC voltmeter
- Junction field effect transistor mixer circuit
- Diode balanced amplitude modulation circuit
- Parallel crystal oscillator
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Wireless microphone circuit
