Two types of multistage negative feedback amplifiers a
Source: InternetPublisher:fish001 Keywords: Negative feedback amplifier BSP transistor capacitor Updated: 2021/01/17
According to the AC and DC properties of the feedback signal, it can be divided into DC feedback and AC feedback. If the feedback signal only contains DC components, it is
called DC feedback; if the feedback signal only contains AC components, it is called AC feedback. In many cases, both AC and DC feedback are present.
The figure shows two types of multi-stage negative feedback amplifiers . In the circuit shown in figure (a), assuming that the bypass
capacitor c:? of the emitter of transistor VT2 is large enough, it can be considered that the AC signal at both ends of the capacitor is basically zero. Then the feedback signal led from the emitter of transistor VT2 through the resistor R back to
the base of transistor VT1 will only have a DC component, so DC feedback is introduced in the circuit. In the circuit shown in Figure 1-38 (b) , the feedback is led from the output end back to the emitter of the transistor VT1
through the capacitor C and the resistor R. Due to the DC blocking effect
of the capacitor , the feedback signal will only have an AC component. So this feedback is communication negative feedback.
The function of DC negative feedback is to stabilize the static operating point, but has no effect on the dynamic performance of the amplifier, such as amplification, passband, input
and output resistance, etc. Various types of AC negative feedback will have different impacts on the dynamic performance of the amplifier circuit, and are
the main means to improve the AC performance of the circuit.
- How are diodes made using semiconductors?
- What are the classifications of filters?
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Beautiful crown wreath made with LED
- Causes of PCB deformation How to prevent circuit board bending and warping
- Share a Motorola amplifier circuit
- Make a flameless electronic candle using simple electronics and LEDs
- Circuit diagram of a differential amplifier circuit
- Digital number selection machine
- Rural vegetable greenhouse lighting circuit
- Farmland irrigation automatic control circuit a
- DC ammeter
- Varactor Diode Frequency Modulator
- OTL low frequency power amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Color display circuit
- Three primary color display circuit
- Small current generator circuit
- Sine wave signal generator circuit
