Linear regulated power supply circuit
Source: InternetPublisher:已注销 Keywords: Linear regulated power supply regulated power supply circuit output voltage BSP Updated: 2020/02/19
The output voltage of the circuit in Figure (a) is adjusted by the potentiometer Rp and has linear adjustment characteristics. Figure (b) shows the relationship between the output voltage deviation Ua and the load current Ia (0-70mA), and Figure (c) shows the relationship between the output voltage deviation Ua and the input voltage Ue.
Main technical data:
Input voltage: Ue=11~20V
Output voltage: Ua=8~18V
Maximum output current: Ia=70mA
Voltage regulation rate (Ue=1V, Ue=15V, Ua=10V, Ia=40mA);
Load regulation rate (Ia=0~60mA, Ue=15V, Ua=10V);
Dynamic internal resistance: R1=60m ohm
Temperature coefficient of output voltage : 3~5X10-5 V/K
![Linear regulated power supply circuit](http://www.eeworld.com.cn/circuit/upload/f1b5037d3e866ac3ebc15b23646f0feb/ff8e2306415c01bb15ac30888dfa7efe.jpg)
- Schematic diagram of car cigarette lighter to USB power port
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- The constant current source composed of two transistors can drive high power
- Miniature polarity reversal power supply using MAX1721
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Charging control circuit made by solar energy
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- Converting a lithium battery charging board into a constant voltage and current charger
- LM317T voltage regulation adjustable circuit diagram explanation
- Crop anti-frost circuit
- Fish farming thermostatic control circuit
- Rural fish farming control circuit
- Agricultural small tractor lighting circuit
- Farmland irrigation automatic control circuit a
- Wien bridge oscillator circuit
- Voltage series negative feedback amplifier circuit
- Color display circuit
- Power phase sequence display circuit
- Home appliance repair signal generator circuit
