Processing circuit for widening stereo effect
Source: InternetPublisher:方世玉223 Keywords: Stereo processing circuit BSP Updated: 2020/10/08
Shown is a processing circuit that performs a broadening effect on ordinary stereo signals . A wide stereo sound effect. This kind of circuit
can be used in radio cassette recorders. The circuit is simple and the effect is obvious. This circuit is composed of two main amplifiers. When the two channels of signal input are separated,
one signal is sent to the input end of the other amplifier through a resistor. The phases of the signal injection ends of the two input channels are opposite, so that each channel has It contains
another signal component with different phases, which is synthesized to have a broadened stereo effect.
The principle of the circuit is to amplify the two stereo signals by two operational amplifiers respectively. At the same time, a part of the signal from each channel is cross-sent to
the inverting input end of the other amplifier, so that each channel will have the inverted signal component of the other channel. This enhances the reverberation component in the music.
This circuit can be implemented using an operational amplifier (4558).
- Share a mini piano circuit
- The easy production of several top-quality tube preamplifiers
- Simple and practical small amplifier
- Make a high-quality DAC board
- Make a pocket amplifier with 8550 and 8050
- Telephone volume amplifier circuit
- Installing a tube preamplifier in the power amplifier
- Using 6P15 to create an ultra-linear push-pull amplifier
- Make cheap speakers using waste circuit boards (TDA1013)
- Tube single-ended class A 300B power amplifier circuit
- Ultrasonic blind pathfinder circuit
- Homemade disinfectant circuit
- Fish pond oxygenation reminder circuit
- Rural fish farming control circuit
- Agricultural small tractor lighting circuit
- Farmland irrigation automatic control circuit a
- Mixer built with analog multipliers
- Inductive feedback oscillator circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Digital stopwatch display circuit
