Audio recorder recording and playback circuit
Source: InternetPublisher:柯南道尔 Keywords: Recorder BSP integrated circuit Updated: 2020/08/21
Shown is a typical tape recorder recording and playback circuit, which uses the integrated circuit TA8-142AP as the core device.
①The recording process. During the recording process, the external audio signal is sent to the ⑩ pin and @ pin of the integrated circuit TA8142AP. After being amplified by the two internal
recording equalization amplifiers CH1 and CH2, the @ pin and @ pin are output to the magnetic head respectively.
② During the playback process, the audio signal from the magnetic head is sent through the @ pin and ① pin of the integrated circuit TA8142AP. After being amplified by its internal playback equalization
amplifier CH3 and CH4, the audio signal is output from the ⑥ pin and ③ pin respectively.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Using TDA2822 to do direct coupler output experiment
- Simple and practical small amplifier
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- Preamplifier made of 6P15 tube
- Installation of electron tube differential amplifier circuit
- Typical applications of optocouplers in audio amplifier circuits
- Class A power amplifier circuit with an output power of 18W
- Tube single-ended class A 300B power amplifier circuit
- American Grado RA1 headphone amplifier
- stuttering correction circuit
- Electric massager circuit
- Particle clogging alarm circuit of wheat seeder
- Soil water shortage prompt circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- ring amplitude modulation circuit
- Diode balanced amplitude modulation circuit
- Schiller oscillator circuit
- Broadband high frequency power amplifier circuit
- Guest arrival signal recognition circuit
