Inverter circuit schematic diagram of Konka LC-TM2018 LCD TV (2)
Source: InternetPublisher:JFET Keywords: Konka LCD TV circuit schematic diagram inverter circuit Updated: 2021/03/24
Shown is the inverter circuit schematic diagram of Konka LC-TM2018 LCD TV .
In the circuit shown in Figure 2-71, the +12 V DC power supply is input from the ① and ② pins of CN1; the power-on and standby (ON/OFF) control signals
are input from the CNI ③ pin: the adjustment control signal ADJ is input from the ④ pin of CN1 enter. The +12 V power supply provides the operating voltage for the drive circuit. In the circuit,
the (D~@ pins of the pulse width signal generating integrated circuit Ul (BIT3106A) output control signals respectively. In the circuit shown in Figure 2-72, the control
signal passes through the drive field effect tube circuit (U2A, U3A), high-voltage transformer (TIA, -12A, T3A) is boosted and turned into an AC high-voltage signal to
power the backlight. Table 2-1 lists the pin functions of its core integrated circuit BIT3106A.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- How to Make a Soft Latch Circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Recommended circuits for different power on times of LM4911
- Simple and practical LED lamp driving circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Dynamic power supply for power amplifier controlled by thyristor
- USB power socket using the car battery
- Converting a lithium battery charging board into a constant voltage and current charger
- Detailed explanation of mobile phone charger circuit diagram
- Power circuit of STR5412
- Power circuit a composed of intelligent thyristor modules
- Portable device charging power circuit design
- Typical Reference Voltage and Power Supply Circuits
- Konka LC-TM2018 LCD TV switching power supply circuit
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- Warm current power supply circuit b
- Low voltage adjustable reference power circuit
- Common power circuits and applications 02
