Inverter circuit schematic diagram of Konka LC-TM2018 LCD TV (1)
Source: InternetPublisher:supremeOne Keywords: Konka LCD TV circuit schematic diagram inverter circuit Updated: 2020/03/31
Shown is the inverter circuit schematic diagram of Konka LC-TM2018 LCD TV .
In the circuit shown in Figure 2-71, the +12 V DC power supply is input from the ① and ② pins of CN1; the power-on and standby (ON/OFF) control signals
are input from the CNI ③ pin: the adjustment control signal ADJ is input from the ④ pin of CN1 enter. The +12 V power supply provides the operating voltage for the drive circuit. In the circuit,
the (D~@ pins of the pulse width signal generating integrated circuit Ul (BIT3106A) output control signals respectively. In the circuit shown in Figure 2-72, the control
signal passes through the drive field effect tube circuit (U2A, U3A), high-voltage transformer (TIA, -12A, T3A) is boosted and turned into an AC high-voltage signal to
power the backlight. Table 2-1 lists the pin functions of its core integrated circuit BIT3106A.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Introduction and principle analysis of switching regulated power supply
- Recommended circuits for different power on times of LM4911
- Miniature polarity reversal power supply using MAX1721
- A simple positive and negative power supply circuit
- Homemade low-power UPS
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage power socket
- UC3842 Electric Vehicle Charger
- LM317T voltage regulation adjustable circuit diagram explanation
- Industrial product promotion and shopping guide DC power supply circuit
- Portable device charging power circuit design
- Power supply circuit with multiple outputs (MAX1902)
- Transistor stabilized current power supply circuit 2
- Timing switch AC power circuit
- Diamond differential input power amplifier power circuit
- Music power circuit
- Konka 60P movement rear projection color TV field fault protection circuit diagram
- Common power circuits and applications 06
- Common power circuits and applications 05
